Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-13-2005, 03:56 PM   #1
RedRocket
RedRocket's Avatar
2001 test drive
I test drove a 2001 5spd QC 4x4 the other day. As you can see from my sig, I currently drive a 97 5spd. Anyways, this 24v had no guts what so ever, especially from 60-70 in 5th. I just didn't seen to have any power. Is this normal for these trucks? This is the first 24v I have ever driven. My 97 will run circles around it. My 97 is a california 180 5spd, and is stock except for the plate being moved forward. Let me know what yall think
__________________
NEW TRUCK
2006 Chevrolet Z-71 Crew Cab LT. Fully loaded nothing left out.
SOLD IT!
03' 2500 Q/C 4x4 ST, 47RE S.O. CTD, 3.73 gears. Quadzilla XZT, boost elbow, True Flow replacement filter, tone ring mod. 285/70/17 A/T tires. 93,000 miles and just getting started.
RedRocket is offline   Reply With Quote
Old 05-13-2005, 03:58 PM   #2
RedRocket
RedRocket's Avatar
guy also said LP and VP-44 were just replace by some guy there at there little roadside used auto dealership.
Old 05-13-2005, 08:43 PM   #3
rattlerbob5.9
rattlerbob5.9's Avatar
Hi redrocket i would say something is not right with that 01 i have a 99 quadcab i ton 2wd 5sp 3.55 gear and at 60 if you want to pass someone you just put your foot into it and roll on around them the best part is the look on their face when that big old truck goes by and they are shocked i don't even need to downshift just give it some throttle and off we go!
__________________
99 quadcab 1 ton 5spd 3.55 213k 2Lp+1Ip org clutch 21.3 mpg
96 3/4 4x4 ext cab LB auto 20.7 mpg stock for a few more days
94 3/4 4x4 auto 181dv-300hp injectors + boost-L- mystery switch- missing kitty -HAVE YOU SEEN HER???
89 3/4 2wd auto the original -with a little pump adjustment
69 GTX 440 4spd super track pack
71 340 duster auto
64 sport fury 383 4spd
rattlerbob5.9 is offline   Reply With Quote
Old 05-13-2005, 08:49 PM   #4
scarecrow
Muted User
scarecrow's Avatar
Quote:
.......yea what he said..........just the other night i was crusing down the highway at 65 the lady in front of me was getting on my nerves so i hit the fast lane and stood on the happy pedal next thing i know i was crusing at 95......
__________________
01 2500 LB, QC, 4x4, auto, 4.10 gears, edge ez, AFE mega cannon, hotrod VP44,turnbuckle on the wastegate, 4in dual straight pipe, removed silence ring , 285/75/16 pro comp A/T`s.....
scarecrow is offline   Reply With Quote
Old 05-13-2005, 08:59 PM   #5
tankeryanker
when I get on the freeway leaving our town, short on ramp on a 45 mph curve. I often have to tromp on it do to truck traffic. I always like to hear the drivers coments on the cb. Man did you see that p/u take off like it was shot out of a canon.
__________________
Tankeryanker Glenn
2005 QC 4x4 nv5600 slt dually, Isspro gauges, Rokktech sensor, few holes in the air box,AFE pro gaurd 7, cool blue hose, MBRP exhaust, pacbrake,new intercooler, Brakesmart cont. , Bigfoot 10.6 TC
tankeryanker is offline   Reply With Quote
Old 05-13-2005, 09:16 PM   #6
J BODY
Judging from the signatures above I would say only Rattlerbob can make a statement on how a "stock" truck performs. My 01 has an auto trans, but I do feel that it is a "pooch" in stock configuration. The simple little EZ made it a whole new truck to drive.
J BODY is offline   Reply With Quote
Old 05-13-2005, 09:38 PM   #7
rattlerbob5.9
j body you are correct my 99 is still stock not for long now though since it is over 200k i think it is broken in and i can start to play with it My 94 auto with 4:10 gears was real dog untill i kicked it in the behind with the injectors and cranked the timing up to 17*- sloppy convertor needs to go but the lockup switch sure helps once you manually lock it step on the skinny pedal and she takes right off instead of all that reving and going noware The 99 is getting the lift pump moved to the rear where it belongs and larger lines then a wake up call with some injectors and exhaust
Old 05-13-2005, 11:18 PM   #8
killfast1
killfast1's Avatar
Mine is still stck with 2 exceptions, And I can go from 60- 90 just passing a car. Its a little of a slouch on take off due to no mods and the torque ramp up from the IP but once I have boost forget it its gone.
__________________
1995 2500 regular cab and its bone stock with 161K on the odometer. unfortunatly its an Auto.
killfast1 is offline   Reply With Quote
Old 05-13-2005, 11:35 PM   #9
RedRocket
RedRocket's Avatar
so basically what you guys are saying is that there is something not right, and that this is not normal. right?
Old 05-14-2005, 04:59 AM   #10
killfast1
killfast1's Avatar
That would be a very good assumption.
Old 05-14-2005, 05:01 AM   #11
killfast1
killfast1's Avatar
Is there any smoke?
Old 05-14-2005, 08:56 AM   #12
rattlerbob5.9
redrocket i have no doubt that 01 has some problems could be simple and could be expensive
Old 05-14-2005, 09:04 PM   #13
RedRocket
RedRocket's Avatar
There was very little smoke. When I looked under the hood, there were two plugs on the driver side by the fuse box that were just hanging there. I asked him what they were for and he had no idea. I have no experience with 24V so I didn;t know if they were diagnostic plugs or what.
Old 05-14-2005, 09:47 PM   #14
NHdodgeman
NHdodgeman's Avatar
There are no diagnostic plugs in that area.
__________________
05 2500 CR Auto
01 3500 24V DRW 6 Spd.
91 D350 12V Auto
NHdodgeman is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
