Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-04-2009, 02:56 PM
dtycoon2003 dtycoon2003 is offline
2001 24V a good engine?
Hi fella's. I haven't posted here in awhile but I am looking to pick up an 01 Quad Cab with a 24v in it. It has a manual transmission. The only experience I have is with the 12v I had in my 92 which I loved.
I remember reading there were certain year 24v engines that had bad blocks. Is this one of them? Any other problems I need to be aware of? Is this manual transmission pretty solid. The truck has 115k miles and looks to be in great condition. I would be trying for the $11k range on price. It looks like it has had some aftermarket work done as it says ATS on the side and "Supertuned by bluechip".
Your input is appreciated.
__________________
92 Dodge D250 Ext Cab 12v Cummins Bone Stock Overfilled Getrag
01 Ram 1500 Sport 4X4 Automatic 360 "Gasser"
Old 11-04-2009, 03:04 PM
stevewes2004's Avatar
stevewes2004 stevewes2004 is offline
thats a good truck. i think the 98.5-00 had the "53" blocks. thats the one to avoid. the manuals are stout. the 5-speeds sometime have problems with 5th gear. 6-speeds are bulletproof but are hard to get parts for. that truck has a VP44 which arent the best but are still ok if you have a good aftermarket lift pump.
__________________
2002 6spd H.O. Drag Comp | DDP 200s | HE351/HT3B Twins IN PROGRESS | 5" Ex. | ISSPRO Guages | Leveled=325/60/18 | Raptor 100 | SB Hydros | SB Con OFE
Old 11-04-2009, 03:08 PM
nkennedy nkennedy is offline
Just keep an eye on the primary fuel pressure from the lift pump. They are good trucks. A little louder than others. 01.5 model year got disk rear brakes, and a manual has the Dana 80 in the back.
__________________
01' 2500 CTD w/ 6 speed, Edge EZ, Boost Elbow, Gauges & Jacobs Exhaust Brake
Old 11-04-2009, 06:32 PM
Clunk's Avatar
Clunk Clunk is offline
Here's some good #53 block info,
http://stamey.info/Truck/Cummins53BlockFAQ.htm
__________________
'01 2500 4x4 Red QC Sport HO SWB, 6spd.,cowl hood, 4" ex., BD Comp wire tapped, Banks boost & pyro pillar mount, single Carter 4601hp lift pump next to the fuel tank Sept. '04, US Gage & 5 grease gun lines for fuel pressure monitor, Power Service in the tank, Amsoil in the trans and Valvoline in the pan, Vulcan Big Line kit, 8psi WOT on 3X5, BHAF, cheapo fuel cooler, big hole injector nozzles, Cat C300G 62-65-.70a/r
Old 11-06-2009, 01:39 PM
SIXSLUG's Avatar
SIXSLUG SIXSLUG is offline
If its a 6-speed try to ensure it has always had the correct fluid in it. The wrong fluid kills this trans in short order and rebuilding can cost a few grand. I have been pretty happy with mine. Watch the fuel delivery system with an eagle eye though!
Kurt
__________________
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus
Arctic White,3.54 gears, Camper/Tow, Stull stainless running boards, A.R.E. cab-hi canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/heatshield, MBRP 4" TBE, FP gauge, Femco E-Z drain plug,DSS, Thuren trac bar, 2" leveling kit, P/H tow mirrors, new intank LP @80K, 91K miles.
Next mod: Smarty, EGT gauge
Support Our Troops! NRA, MSBL, BYO
Old 11-07-2009, 03:34 AM
Thanks for the info and replies. After closer inspection I have decided to pass on this truck and keep looking. It had way too many aftermarket parts for my liking and the injector pump was shot already. (The dealer was in the process of getting that fixed)
__________________
Old 11-07-2009, 07:33 AM
Clunk's Avatar
That's right pal, nobody's holdin' a gun to yer head...pick your best deal.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
