| View Poll Results: 2-Cycle Oil in the Fuel Tank? | |||
| Yes |
81 | 78.64% |
| No |
11 | 10.68% |
| Still not sure... |
11 | 10.68% |
| Voters: 103. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
Ok everyone this is it!
We have all read the countless 2-cycle oil posts, threads, write ups etc. Lets settle this once and for all. All of the information has been put out on the table and its all been digested. To keep the old research in the past and bring what people now know to light...... Should we run 2-Cycle Oil in out trucks Yea or Nay and Why.... |
#2 |
Well I'm not sure about long term use and it helping, but I will say that my truck sure runs quieter and seems to be freer. Mybe its just that I think its better so it is but I sure notice it when its not in the fuel. Been using it for a couple years now and plan on keepin' on.
__________________
2001.5 auto QC 4X4 3.55's and lots of babying. Just remember " We are free to do what we want as long as we do what we are told. " Too many laws. Where did we go wrong? |
#3 |
YES , I use 16 oz to ever 40 gal of fuel. Truck has run good for the past 5 years. I also am using the orginal lift pump.
__________________
2004.5 Dodge Ram 3500 Quad Cab SLT AKA Blue Thunder 48RE Trans w/Mag-Hytec DD Pan @ Temp Gauge Rhino Bed Liner/Westin Nerf Bars 18K Reese Signature Hitch Viper Security System 50-Gal Aux. Fuel Tank 2003 35' Cardinal Fifth Wheel -AKA Motel 9 |
#4 | |
Quote:
I have been running Wal-Mart SuperTech, 16oz at every fill up, usually between 1/2 & 1/4 tank for almost 3 years. It quiets my injector rattle, thats the only apparent result thats noticable. I sent my injectors to Formula 1, through Rip at Source Automotive, Rip relayed to me, that my injectors, these are his words, "were cream puffs". Translation = Virgins/New/Solid, 2 CYCLE OIL has not hurt them.
__________________
"We're surrounded...that simplifies our problem" 2003 HO QCSB 3500, DTT 48RE, BD R700 Twins, Formula 1 Injectors, GDP fuel delivery & Intake Horn, 5" MBRP Exhaust, Dipricol Gauges. 4.5" Lift, 35/12.50/18 Toyo MT's on 18x9.5 American Eagles. TST / EZ / SMARTY 411 622.80 HP / 1147.98 TQ 08/23/09 Spokane Diesel Thunder |
#5 |
well since my truck is not designed to run off the ultra low sulfur stuff i always add some 2 stroke every other tank, It also helped smooth out my idle.
__________________
2005 Patriot Blue 2500 CTD [325/610] QC 4x4 48RE 4.10 Gears Off-road pkg Manual high idle Born 10-04 Silencer ring MIA S&B cold air intake TS shift enhancer Rokktech crank sensor Custom intake manifold w/ 4 ports 5 inch turbo back exhaust w/ 6 inch tip Quadzilla Xzillaraider II Gone but not forgotten. :( 99 Laramie Reg. cab 2500 4x4. I hope the new owner takes good care of her. NRA Member |
#6 |
Ad-meany-strator
Depends. I think on the VE and VP44 pumped trucks it a a good idea. The P-pump would probably be just as happy pumping gasoline or paint thinner as diesel fuel. The commonrail trucks probably don't need it either.
__________________
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD Dead KDP's = 72 |
#7 | |
I run it in every tank. Then again I run 8 months or so every year on #1 as well.
__________________
-40* keeps the wimps away but I WANT A (BIGGER) GARAGE! 92 CTD Club Cab 5spd. Banks 14cm w/g turbo, 3.5" exhaust, pyro/boost/oil pressure/coolant temp/trans temp gauges, 190s, 3200 spring, pump tweeked, Hot-wired KSB, K&N, add-a-leafs and airbags. 225K & still rollin' Proud Member- Alaska Correctional Officer's Assciociation. "Walking Alaska's Toughest Beat" Quote:
#8 |
16oz nearly every fill up.
Quiets the 'rattle' significantly. ![]() As for added lubricity equaling extended longevity of the VP or Lift pumps, hard to say. I installed a Glacier Diesel Walbro system to eliminate the junque stock pump, and I have replaced two HR-VP44 Injection Pumps that only lasted 1 1/2 years each with a Blue Chip pump. ![]()
__________________
'99 3500 SPORT BlackClick for Picture Gallery DTR Site Moderator |
#9 |
What ratio is everyone using?
I've always heard the best is 128:1 |
#10 | |
Quote:
1oz per gallon is a good rule of thumb. Thats what it is for my truck anyhow.
__________________
'93 1-Ton, S/Wheel, S/cab, 4x4 AmsOil 277K+ KDP: Dead Oct'07-2ndTOM TXDTR #42 They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -Ben Franklin With building a car there's one rule you have to remember; fast/cheap/reliable. You can only pick two. I might be a drunk but I'm rational. -Doug Stanhope Don’t blame me, I supported Ron Paul |
#11 |
Just started using it today!
#12 |
I tried it last week. A couple of interesting things happened. I recently installed a lift pump from an 8.3L and it was starting to take pressure dives. It would go up to 17psi and down to 4 or 5psi. Right when I was going to tap my new pump or take it apart to see what was messing with the pressure regulator, I read one of the posts on 2cycle oil. I went to Orielly to get some Valvoline and all they had that looked any good was Lucas. I got a quart and threw it in the FULL tank. It did get quieter but it seemed to get sluggish. The interesting thing though is the fuel pressure came back up after a few minutes and stayed up. Due to the sluggishness I think I will try Marvel Mystery Oil next.
__________________
Oilfield diesel mech. in S.Texas. '02 3500 drw 4x4 SLT Laramie: Inj. pump @205k miles. 8.3L ISC sply pmp,Vulcan draw straw, 1/2" fuel line, big line kit, Big Hoss tnr,strt exhst, s. ring mia, k&n air fltr, pure power oil fltr, fuel pres, bst, pyro, and trans temp guages, mag-hytec pan, cstm bilt g/n hitch. '05 3500 srw 2wdr. SLT: k&n air fltr, s. rng mia, hider g/n hitch. 50hp DDP nzzls comin. " Never argue with an idiot, he'll drag you down to his level and win through experience" |
#13 |
And BTW, How do I get the "Registered User" under my name changed?
I use 16 oz about every other fill up depending on my driving.
__________________
Tow vehicle...2006 Atlantic blue Mega Cab 2500 4x4 6 spd. 3.73's CTD 325/610.. Silencer Ring gone...Amsoil EAA189 filter... Air Box mod... Quadzilla Max Mileage Module... Fuel Tank Vent Mod... Muffler gone Member #3 of DTR Megacab Club Join Here Member #12 of DTR GoofBall Club Join Here Towed.. Jeep CJ7, 304 with Holley Fi, T-18 trans, Dana 300 with 4 to 1 gear set, Dana 44 with Detroits F&R, 35x16.5x15 Boggers with MRT bead Locks, and way too much more to list. |
#14 |
Additives
1-2 quarts of ATS trans fluid every tank full! Last 14 years!
__________________
1994 12 valve 4X4 Fully loaded Carli Suspension with 3" Kings Suncoast full billet trans converter & Flex plate HX 40 370 injectors Snow Performance Meth h20 injection 315-75-16 Pro-Comp Extremes Wilco tire carrier Keeps up with the traffic!Thanks to Old Man Bob 4X4 & Pablo |
#15 |
I lost 2 LP after I started using it. One was a Walbro after 2 yrs and 25,000 miles, one was an Airdog after 500 miles! Not sure if it was cuased by 2-stroke or not, but that is the common denominator for me, so I will not use it anymore. Power Service it is!!
__________________
Eric Looking for a Megacab... "SOLD" 2002 3500 QC 4x4 Dually with a bunch of mods... "SOLD" 1989 W250 4x4, with a bunch of mods... |
| Thread Tools | |
| Display Modes | |
