Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Cummins Conversions
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 02-03-2009, 11:00 PM   #61
1-5-3-6-2-4
1-5-3-6-2-4's Avatar
here what I have of the mounts and rail. not the best but all i got right now. I'll try to get a couple better ones from underneath tommorrow
__________________
Luke
'97 Chevy V3500 CC DRW 6BT 22" Alcoas
'98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold*
'90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg
'73 RS/Z-28 Survivor.
1-5-3-6-2-4 is offline   Reply With Quote
Old 02-03-2009, 11:24 PM   #62
RuralCruiser007
Send a message via Skype™ to RuralCruiser007
Lookin great Luke.
Most of the motor mounts I have seen they are using the Dodge isolators from the First Gen Cummin's. With the ones you are using incorporate the GM mounts. I feel with this you can urethane after factory mounts. Care to indulge who you got them from?
Looking forward to see more information from you on this.
Oh, by the way, did you use the GM rad with the second gen intercooler or the rad and intercooler from the second gen?
Thanks,
Glenn
__________________
"MOOSE"
91.5 W250, Intercooled, Getrag 5 spd
Autometer Cobalt Boost and Pyro
BHAF
3" Downpipe, 4" back, Dynomax Muffler
PDR Bosch 190's
Borgeson Steering Shaft
Tweaked Pump - 366 Spring
HX35W Turbo
KDP Addressed
Booger
81 VW Rabbit Diesel
50+ MPG
RuralCruiser007 is offline   Reply With Quote
Old 02-04-2009, 12:48 AM   #63
1-5-3-6-2-4
hey glenn, I got the mounts from "crewcab59" scott @ Tennesse Diesel conversions. very bolt in. no body lift no frame notching.
I used the rad and intercooler out of the '95 the rad is so much bigger than the GM one I just had to use it. and fits around the intercooler perfectly obviously. it is a tight fit with the CAC between the headlights. had to cut alot of the rad support out to fit. and have to reinforce whats left.
there is some lean to the rad and CAC but the stock GM rad clamps still work. the rad will not come out the front without removing the headlights. or pull the rad and CAC as a pair out the back.
Old 02-05-2009, 11:19 PM   #64
torquefan
torquefan's Avatar
Hey Luke,
I just stumbled across this thread and had to read the whole thing. Quite the ambitious project, and it looks like you did great. It didn't sound like you had any huge problems that took forever to get around. Anyway, congrats. You are probably almost ready to start driving it soon and I'm looking forward to seeing pictures of it all together. Are you planning to do the paint right away, or wait a while?
Dave
__________________
1996 Ram 2500 Club Cab, 4x4, 5 speed, KDP tabbed, Prodigy, Silverstars with relay kit, BD 4" cat back, Autometer gauges.
I've donated.
torquefan is offline   Reply With Quote
Old 02-06-2009, 05:57 PM   #65
974door
974door's Avatar
Does the oil pan hang down below the crossmember?
974door is offline   Reply With Quote
Old 02-07-2009, 05:55 AM   #66
1-5-3-6-2-4
Quote:
Originally Posted by torquefan View Post
Hey Luke,
Dave
thanks. its been a long haul though. working in bits on it
Paint, not right away. going to wait until at least winter is well over.
Cross member? my truck is a 4wd. theres a diff under there thats bolted to the framerails. the sump will always be a rear sump though. and it is behind and below the diff area. but not lower than the lowest point if that what you're after.
Old 02-08-2009, 07:14 PM   #67
974door
974door's Avatar
O.k. Thanks. I didn't realize your was a 4x4.
Old 02-16-2009, 01:54 PM   #68
1-5-3-6-2-4
heres the divorced Ford NP205 mount. got it final installed last night. used 3 of the 4 OEM isolators. 3lb sledge for custom clearancing floorpan. grind 2" off the top of the driverside case mount to clear.
Old 10-25-2009, 11:16 AM   #69
DragonSlayer
Found this old thread....any updates??????????
Looks great, I'm looking at a dually now for a swap, need some more info.
DragonSlayer is offline   Reply With Quote
Old 10-25-2009, 12:11 PM   #70
Hvytrkmech
DTR's "Puttin fires out and workin on big trucks" member...
Hvytrkmech's Avatar
Nice job on the install. Hows it run?
__________________
Tim
2006, 3500 QC/SRW/LB/48RE/4.10/Inferno red, Mag-Hytec trans and diff cover, Isspro gauges, Quad XZTII, GDP 2 micron kit, Air Dog 100, install with pics- http://www.dieseltruckresource.com/d...d.php?t=185809
Hvytrkmech is online now   Reply With Quote
Old 10-25-2009, 03:47 PM   #71
1-5-3-6-2-4
Oh works good. had it in there 9 or 10 months, then my OCD (Obsessive Compulsive Diesel took over) so I ripped the truck apart. and an putting my cab box and driveline onto a 2006 F450 4wd chassis.
Old 10-25-2009, 03:53 PM   #72
1-5-3-6-2-4
so another field tech rolled is service truck. company is self insured. so we parted it out. I bought the whole rolling chassis cheap. no damage.
Old 10-25-2009, 05:26 PM   #73
Hvytrkmech
Hvytrkmech's Avatar
WOW, that is a real bad case of OCD. You are going to confuse a lot of people when that truck is finished. Ford chassis with a Chevy cab and a Dodge engine/tranny.
Nice job!
Old 10-25-2009, 07:04 PM   #74
sdseva
sdseva's Avatar
Frankenstein!!super bada$$
__________________
92' club cab le, long box, rag, 4x4, gauges fuel/boost/pyro, 3" straight pipe, star down, pin turned, power screw in a little, 366 spring, 1/8 bump, silencer ring MIA, BHAF, auto oil undercoat, a little loud, a little smokey
Steel wheel club Member#5
sdseva is offline   Reply With Quote
Old 10-25-2009, 09:58 PM   #75
1-5-3-6-2-4
Ya the old Albino Rhino is more like Franken-Truck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
