Thread Tools | Search this Thread | Display Modes |
#1 | ||
1993 VE Pump control valve issue
#2 |
Solved!!!
The local Cummins parts house called a pump rebuilder and got me the answer. I described to the rebuilder on the phone what the parts looked like. He told me the tiny hole in the piston faces down into the bore where the control valve (pressure regulator) sits. The rebuilder says that guys that play with pump pressures have this happen more often. But it happens in stock pumps as well. The clip goes in only until it's flush with the bottom of the control valve. The top of the control valve can be pounded down with a drift and hammer to increase the pressure he said. Also he mentioned that if I did that the pump would have to be calibrated again. Now worries here, this old girl is staying stock. The pic shows the correct way this valve goes back together.
#3 |
The first pic is the using the large channel locks to push in the clip.
The 2nd pic is the clip in flush as the pump shop recommended. The 3rd pic is after I drove the clip inward more with a philips screwdriver. Shake the valve when you are done. It should keep rattling, but just barely. I could see that the gap between the piston and the clip was set up to have the clip pushed right up to the inside edge of the chamfer, but no more. I actually overshot a bit. I am reporting all of this info on my blog (link fixed): http://www.rotordesign.com/1993cummins |
#4 |
Turns out that the valve is working fine. A 207 mile trip was almost 26 mpg at 65mph.
| Display Modes | |
