1992 W250 Resurrection/Modding
Old 06-16-2014, 10:51 PM
  #46
MrFusion's Avatar
I also put new Hastings air filter in.
Old 06-17-2014, 08:39 AM
  #47
mknittle's Avatar
That is CAT yellow it won't work on a Cummins.
Old 06-17-2014, 01:02 PM
  #48
Received 1,331 Likes on 862 Posts
I really like your overkill air cleaner wing nuts....those are sweet!! But that darn yellow keeps popping up everywhere....
Old 06-19-2014, 12:45 AM
  #49
MrFusion's Avatar
Actually its "Valspar Equipment Yellow" so it'll work just fine on the Cummins . It was either that or Ford blue.
Old 06-19-2014, 12:46 AM
  #50
MrFusion's Avatar
I still have about 20 cans of it so it's a safe bet you'll see it again...
Old 06-19-2014, 10:00 PM
  #51
I look forward to playing..."Find the yellow parts".
Old 06-19-2014, 10:28 PM
  #52
MrFusion's Avatar
Makes it easier to figure out what I've already done
Old 06-20-2014, 07:22 AM
  #53
mknittle's Avatar
Old 07-02-2014, 12:49 AM
  #54
MrFusion's Avatar
This is for Cows, Mark and Ollie!! Exactly 20 spray cans of Equipment Yellow, 2 cans of Kubota Orange, 4 quarts of Equipment Yellow and a gallon of Red Oxide Primer!
Old 07-02-2014, 01:02 AM
  #55
MrFusion's Avatar
I replaced the chintzy, thin walled, weak excuse for a rear trans mount that came with the AA NV4500 conversion kit with actual 3x3x.25 inch steel tube. I should've done it when I installed the trans but I had misplaced the piece of square tube. I should have milled the slots in the mounting plate on the cross member about a quarter inch longer but it's in and it's solid. The mounting plate is a bit crooked now. Here's a comparison of the old mount and the new one.
Old 07-02-2014, 08:47 AM
  #56
mknittle's Avatar
And a partridge in a pear tree. It must be good because I can't find anybody that still sells it here any more!
Old 07-02-2014, 08:57 AM
  #57
mknittle's Avatar
That looks better.
Old 07-28-2014, 11:56 PM
  #58
MrFusion's Avatar
Been a while since I wrenched on the truck. I got the trans tunnel cover done and painted (yes...its yellow). I had to rework the sticks on the twin stick. I basically had to straighten them so they stick straight up. I had to do this so that the boot for the twin stick and the boot for the shifter wouldn't be on top of each other. I sent the sticks out to get powder coated.
I'm trying to figure out how to seal the tunnel cover to the tunnel so that it's reasonably water resistant yet will come off fairly easily. I thought about using foam rubber weather stripping (like for doors and windows) but was afraid it will hold moisture and create rust. Right now I'm thinking of using blue RTV. I welcome any thoughts or suggestions.
Old 07-29-2014, 07:09 AM
  #59
Alec's Avatar
I would use either duct seal (the black putty used to seal around electrical conduit), or a small bead of sika flex (urethane construction adhesive caulk).
All surfaces painted well before sealant application.
Most RTV is to stiff to seal sheet metal well -- as the metal flexes, or even just changes temp, the RTV will peel instead of flexing. It also releases a mild acid when it cures, which can initiate corrosion if there is a flaw in the paint . . . I used to use RTV as seam sealer all the time, but it didn't really work out well in the long run.
Old 07-29-2014, 07:26 AM
  #60
mknittle's Avatar
years ago there used to be a rope calk product that was used to seal between fenders and body panels. Eastwood may have it. it was called body putty but a search for that comes up with bondo type products.
Quick Reply: 1992 W250 Resurrection/Modding
