1992 W250 Resurrection/Modding
Old 05-26-2014, 11:44 PM
  #31
MrFusion's Avatar
Old 05-26-2014, 11:48 PM
  #32
MrFusion's Avatar
Wow a welded up output shaft...That is crazy!!
Glad you got your new "Yellow" tranny into the truck.... Does your new Clutch slave cylinder have a bleeder?
There's my new yellow NV4500 next to the old broken Getrag.
Old 05-27-2014, 08:55 AM
  #33
kiszka6911's Avatar
Your truck has the same paint scheme as mine, I am rebuilding mine slowly, my cab is not worth saving so I found another. Then I got a sweet deal on a front clip. It just takes time. Make a plan, write it down, prioritize it so that funds are focused on the needs at hand.
Old 05-27-2014, 09:14 AM
  #34
mknittle's Avatar
Originally Posted by MrFusion
Looks like something a kid would do.
Old 05-28-2014, 10:46 AM
  #35
MrFusion's Avatar
I got the twin stick adjusted how I want it. Now I need to pull the shifter sticks themselves out and get them powder coated. I am half way through the process of killing the KDP. The good news is that my KDP is right where it belongs and hasn't moved.
Old 05-28-2014, 11:56 AM
  #36
Received 1,332 Likes on 862 Posts
Wow...can't believe they tried to weld that shaft!! Sure is a purdy yellow tranny you have there....
Would like to see your twin stick set-up...sounds interesting.
Old 05-29-2014, 12:18 AM
  #37
MrFusion's Avatar
That's kind of cool that we have the same paint scheme. I don't like red but the truck was a mile from my house and the price was right (almost). The twin stick was a semi frivolous expenditure. But I figured since the floor was cut up and the front drive shaft was off I might as well go for it. My priorities are to get the truck: to move on it's own (done), to get it roadworthy (needs brake and steering work), to get it inspected and on the road (needs a fair amount of rust rehab in the cab and a little on the frame, stupid little stuff too, tires), get it reliable (needs unknown at this time but I have been considering various upgrades), start tweaking performance.
Old 05-29-2014, 07:58 AM
  #38
mknittle's Avatar
One of the benefits of the twin sticks are it is easier to shift. That alone has got to be worth something.
Old 05-29-2014, 11:21 AM
  #39
How hard is it for others to get their transfere case into, and out of gear? I know mine in the crewcab is almost friggin impossible!! Moving or not.
Old 05-29-2014, 03:35 PM
  #40
Alec's Avatar
I have come to believe that a lot of the problem if the case is hard to shift comes from crudded-up shift rails. My AZ truck shifts really well. The Blue truck I put twin sticks in, because it would shift into front high before rear high with the stock linkage, so you couldn't shift on the move 4 lo to 2 hi with the hubs unlocked . . . when I rebuilt that xfer case the stock rails were cruddy enough that they stuck in the bores. I always try to shift into 4 lo when I park in the winter now, to wipe the salt off the shift rails, and leave them inside the case while the truck is sitting.
Old 05-29-2014, 04:45 PM
  #41
mknittle's Avatar
That is because you are moving two shift forks with pretty strong detents at once. add any load to that and it only gets worse.
Good spring actuated hubs help too.(sorta like being in two places at one time) I hated my old Selectros on my Chevy(worm gear actuated) Sometimes You had to rock the truck back and forth just to get the hubs locked.
Old 05-29-2014, 07:03 PM
  #42
Transfer case is newly rebuilt. Cleaned up the rails, and new ***** and springs. Should shift smooth as silk in my mind anyways....
Someone should engineer up an old hurst shifter to use as a TC shift mechanism. Then you could have the easy of a twin stick...on a single shifter. Hmmmm....goes outside to look for old shifter parts.....
Old 05-29-2014, 11:19 PM
  #43
MrFusion's Avatar
Mine goes in and out of gear pretty well now! It isn't quite smooth but has a nice positive feel when shifting. The only odd thing is that the front axle shifter has about twice the throw of the rear axle shifter.
Old 05-31-2014, 09:03 PM
  #44
MrFusion's Avatar
I finished tabbing the KDP, put everything back together and realized I forgot to put the dust seal on the end of the crankshaft. I guess I know what I'll be doing tomorrow.
Old 06-16-2014, 10:50 PM
  #45
MrFusion's Avatar
I made some home made air filter nuts out of 1/2" wing nuts and 1/4" coupler nuts that I welded with a torch. The welds aren't the best but that's what I get for being too lazy to set up the mig welder. Maybe overkill but was probably easier and cheaper than trying to find the OEM plastic nuts. And I painted them yellow!!
Attached Thumbnails 1992 W250 Resurrection/Modding-img_2298.jpg   1992 W250 Resurrection/Modding-img_2299.jpg
Quick Reply: 1992 W250 Resurrection/Modding
