Thread Tools | Search this Thread | Display Modes |
#1 | ||
12cm is on
__________________
Bill 91.5 D350 regular cab dually 3.54, Built 518,Goerend convertor,potentiometer, isspro tach, 60psi boost gauge, pyrometer, trans temp gauge, fuel pressure gauge, 4" de exhaust, bd killer b 63/68/14, arp studs, ported and polished head, 3 piece manifold, 366 spring, DennyT II, Half turn from runaway, dap 5x14's, grid heater delete, custom air box and bhaf. Fass and 1/2" fuel lines . 208,000 mi. Kdp killed. |
#2 |
Would about EGT's on the top end ?
__________________
91.5 W250 4x4 5 speed LE Red/Grey, 270k miles, 3.54's w/ Power-Lok, 4" Exhaust, BHAF, DennyT Pin, 3200 Spring, Piston LP, Power screw maxed, HX35/12cm, DAP 5x14 Injectors, Valair 13" 550hp K/C clutch, 4" Skyjacker soft-ride lift, 315/75R16 Mickey Thompson Baja ATZ tires, 16-17 MPG 89 D150 3.9L TBI/A999 Auto, beater while ^^^ gets restored Attending LTI for Diesel Truck Technology, graduate December 2013 |
#3 |
I haven't checked the egt I am just impressed with how much it cleared up the smoke down low. It has much better low rpm manners. I did notice that I gained about 4 psi of boost.
#4 |
hey-Hey!!!,
Looks like I'm now in the market for a V-band outlet and a waste gate controller that can mount with a clocked cold-side scroll on my HX35... but first on with the 16 cm housing.cheers, Douglas
__________________
1990 D250, NV5600, Luk 05-101, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07, HX35...IC soon She wasn't built to travel at the speed a rumour flies 1991 D250, 16cm housing |
#5 |
You will love it!!!!! I just gotta check on egt now but they should be ok I dont tow much so I am not real worried.
#6 |
glad you like it!!
__________________
1992 w250, 366 spring, getrag, boost pyro gauges, fuel screw all the way, denny-t pin, hx35 12cm, 4" exhaust Chevy rear leaf springs with shackle flip, skyjackers up front |
#7 |
#8 | |
Quote:
__________________
90/97 F350 4x4 SRW Crew/long Fummins |
#9 | |
Quote:
#10 |
I hear ya, and I wasn't busting on you, actually giving thumbs up for the 12cm install. For a driver with 300 or less hp to the ground, it's hard to beat the 12. Street manners are awesome and torque is just rediculous
CowboyCustoms and I put a 12 on his '93 and it was just wicked and wouldn't break 1300. Any more fuel and the compressor side of the charger is just out of wind anyway, regardless of ex housing.
#11 |
I know you werent busting me no worries. I was suprised that I actually gained 4 psi I didnt think I would gain much. I thought it would just change when the boost comes on.
#12 |
Right one...glad your liking it. Is your truck auto or manual? I'm trying to decided if I should go 16 or 12 with my NV4500? Think most guys recommend the 12 for a manual trans truck.
__________________
1984 Dodge Crewcab, D350, 1 Ton SRW, long box, 89 CTD, stock with 283K Kilometers, 366 spring, 1/8 timing bump, Fluidamper, Isspro Tach/Boost and Pyro Gauges, KDP killed, no I/C, piston lift pump, 2nd gen fuel heater, 3" exhaust, 96 NV4500 5spd with filter kit, Dana 60 with open 3.54's. |
#13 |
Bills truck is an auto.
#14 |
I checked the egt last night and on a wot run from 0 to 80 it only got to 1150. I don't hardly even have any smoke any more.
#15 |
I drilled the divider on my housing before I put it on and noticed really no difference at all on top end egt from my 18cm housing.
__________________
1990 D-250, Getrag overfilled, 3.54, Full Power Screw + 1.5 turns, Stock Inj, BHAF W/4" custom intake , Stans 4" w/straight pipe, Autometer Gauges, Air Lift Overloads, Amsoil in Everything, Homemade Front Bumper, Borgeson Steering Shaft, Eagle Alloys, KDP KILLED, 1/8 Timing Bump, Gillett 60mm compressor, 12cm w/g exh ported, gated @ 28 psi, 366 spring, Banks Intercooler, Pusher High Ram Intake, Denny T Stage II, LP Piston Pump, 22 MPG, |
| Display Modes | |
